X_Factor wrote:Silver flutes
Exodus anarchy
nervewrecker wrote:Thats a good deal.
Never underestimate those cheaper brands
altec wrote:1000.00 and under.... could pop over a bit....
Ted_v2 wrote:as of recent, anyone else came across something locally?
my doors are properly well done, but the output is very limited, currently running a pair of CDT woffers at 75RMS per speaker, system sounds very poor without the sub.
Ted_v2 wrote:already active, not enough midbass. Evolution7tt and i did some eq changes with his Mike, it improved from the first install to now, i guess my ears get so accustomed to it. Ill try another little adjustment on the tune and see if it improves, if not ill get in touch with you xfactor for those exodus. as i heard them already in this same install and it was good.
Pirate wrote:Ted_v2 wrote:already active, not enough midbass. Evolution7tt and i did some eq changes with his Mike, it improved from the first install to now, i guess my ears get so accustomed to it. Ill try another little adjustment on the tune and see if it improves, if not ill get in touch with you xfactor for those exodus. as i heard them already in this same install and it was good.
Are your doors deadened?
I had some CDTs a while back and while I was testing my neighbour was asking me if I had a hidden sub in the car. It was just the door comps. Feel like ah shilling one time.
